04.18.2006, 11:07 AM
14 cells on a 10xl with a 9920 esc. If you running about a 150 mm tall tire about a 18 or 20 should work out fine.
That is mod1 with 51 tooth spur.
Peace!
Country
Help support the
Rc-Monster
Buy here
04.18.2006, 11:28 AM
This is going to be a dumb question, but what is a mod1?
04.18.2006, 11:31 AM
I'm running prolines rims and tires, not sure of the size, they are almoset the same if not the same size a the stock tires. I found the mod1's harden steel. I ran 72/11 with my hv though. 51/?? i guess would be the question with the tires i have...plus, i think my truck is a little on the heavy side...should i be concerned with heat?
04.18.2006, 11:33 AM
It's the pitch of the gears that 1/8 nitros use which is stronger than the stock 32 pitch on the e-maxx,the strobe slipper fits a 51T mod1 spur gear,you'd need mod1 5mm bore pinions with it.
04.18.2006, 11:49 AM
Right now i have the robinson racing slipper, this will not work? Would you have a link for the strobe kit?
I really appreciate it guys. All this help is awsome.....THANKS!
04.18.2006, 01:26 PM
04.18.2006, 02:03 PM
Thanks boss. Does the kit come with the pads? I got one ordered now, but it didn't say if it came with pads...thanks for the link.
04.18.2006, 02:23 PM
OK. Now after having 3 pages on a thread. I think I'm set. I have:
Robinson Racing Slipper & Strobe Set up
9920/10XL
MIP center
Dynamite cvd's
dynamite aluminum rear bulks
Integy front a-arms
Proline tires and rims
IB3800 7 cells
Mod'd stock chasis
Mod1 16/51T (plastic, not sure if it will hold up, we'll see)
So, i should be set to go until i smash it to pieces since most everything is stock!
04.18.2006, 02:37 PM
no problem.im pretty sure the slipper doesnt come with pads.
04.18.2006, 02:58 PM
cool thanks a mill!!!
04.18.2006, 03:16 PM
No pads in stock...:oP...will the robinson work for now?
04.18.2006, 03:55 PM
ok, the slipper DOES come with pads, not the stock slipper plates though, youll need those but you should have then from the original slipper. as for gears, well 14/51 is WAY to low. more like 20/51. thats what i run, i think a 18 will be slightly better though. i would get a 18 and 20.
04.18.2006, 07:32 PM
Yeah! The slipper comes with the pads. You order a spur gear to fit the strobe. Need the stock plates like squee mentioned to. I also agree with the gearing. 18 or 20 51
Peace!
Country
Help support the
Rc-Monster
Buy here
04.19.2006, 09:19 AM
Ok guys! Glad to hear it comes with pads. I still have the stock plates so that's awsome. I got a 16 because I wasn't sure about the steel gear going with the nylon 51T and i think it was out of stock though too, will it still work?
04.19.2006, 09:39 AM
It should work, im gonna be recieving my package soon with my gears in there! 16/51 on a 10L :)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
