Sylvester
Sylvester's Avatar
04.27.2006, 05:54 PM
Leroy, re-bind your receiver, than try again. Isnt the transmitter called a "tx" ? And the receiver "rx"? Kinda confused...
Anyway i did some testing today, i took off the pinion and sat the truck on my backyard porch, turned on the tx and than the esc. Everything was fine, no sudden reverse (like you have, right leroy?) and i started to walk further away from the truck, everything was fine, i hear the motor responding to me as i moved my finger on the accelerator (throttle). Also tried the steering, works fine as well.
Do you think this is a ok way to test it, i am still a little scared to put the pinion back on, but ill have to sooner or later.
Also, i have found out that if i put the UBEC into the "AUX" slot in the receiver, it works, same if i put it in the "BATT" slot. Does it really matter?
Cabking, just read your post, i got a switch with my spektrum, did you use that one? Ill try it out if i have to! Thanks!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
