Superemaxx89
04.03.2005, 05:42 PM
i see a couple of very costly problems you will have...
The schulze 18.97 is made for 18 cells. Most people burn them out on 16, running them on 20 cells i a given that you'll burn that esc out.
(unless this is a show truck) The aluminum body mounts should be replaced with plastic. Plastic absorbs impact, unlike the aluminum which will just transfer the stress into your shock towers. I'd rather bend a 5 buck plastic body post than break a 20 dollar body post, or 50 dollar shock tower.
(unless this is a show truck) you should replace the aluminum bumper mounts with plastic. The aluminum bumper mounts bends screws and breaks bulkheads, aluminum or plastic.
Also, since your esc is turned sidways, the heat still travels up. And since your heat sink is to the side, it will become usless, you will be experiencing some overheat there.
very nice truck you got! Just keep what i said in mind when you bash. love that wheelie bar!
