MetalMan
MetalMan's Avatar
06.11.2006, 10:24 PM
You could take two 5s packs and run them in series, and charge them individually. But, the A123 cells are most likely connected together using thin (welded) nickel strips, so you'll want to rebuild the pack. Just make sure that if you do this all of the tap wires go where they were before you disassembled the pack.
I haven't read anything special about the A123 cells. What I have read people seem to be saying that these cells are similar to the Emoli cells in that after a certain current is passed, the voltage starts to sag (~35amps for the Emoli cells). The A123 cells are a lower voltage, their max charge voltage is 3.6v, compared to Emoli/Lipo of 4.2v. That puts the nominal voltage of the A123s ~3-3.2V. And I still haven't read anything on them about LVC voltage if it's necessary and if so at what voltage it should be set to.
06.11.2006, 10:32 PM
Thanks.
Actually I was talking about running 2 x 5s1p packs in parallel on the truck, but then charging them as 10s1p using a different Y cable.
I read the information about the M1 cells too. That low 3.6v charged voltage is probably the only thing keeping me away. However, if I use the "stock" charger, all should be well. Still, they're bigger than the EMoli cells, have less voltage, and less capacity. The only reason I'm eyeballing them is for the safety aspect and the fast charge time is nice too. In the end, I'll probably end up with Lipos. I just wish the "Holy Grail" of batteries would come out soon, but that won't happen until the day after I make my purchase. :rolleyes:
