Rusty
04.07.2005, 03:46 PM
Allright thanks, I think i'm gonna go with the MGM80 and a Lehner 5300 with next week's paycheck.
RCcarnut, As long as your running the stock control arms, you can take the rear out-drive cups, stub axle, and dogbones from a HPI RS4 MT, and with a little spacing with some fiber washers you can get it to work so the dogbones wont fall out. I know some guys on the traxxas forums made a nice diagram and everything for the conversion, do a search on there for it if your interested. I used to run that setup, but i used to break the stock control arms toooo much, so now i run RPM arms from an RC10T and the stock half shaft setup because the RPM arms are about 1cm shorter :(
  Send a message via AIM to Rusty
