COOKIES!
Another Lipo thread -
06.13.2006, 04:52 PM
Not far off now and looking for a 3s and 2s pack, for around £150 for both ($300).
I like the look of the Flightpower ones bascily because they are in the UK and the quality, however, they don't do any higher capacities of a decent size over 3700mAh? I seriously don't want to make my own Lipo packs. So don't suggest it. :D
The TrueRc ones look too cheap to be true (no pun intended), they do a 3s 8000mah for $100... that seems great. Does anyone know the discharge rate and what they can be charged at too? Something I really want is to be able to charge it at decent rates, like 1C (for a 8000mah pack that is 8amps would I be right in saying?).
Thanks guys.
06.13.2006, 05:38 PM
Just FYI, all Lipos can be charged at 1C. Some claim to be greater than 1C capable for charging, but in reality that's possible for all Lipos. Usually, greater than 1C charging is only recommended when either the charger has a built-in balancer or the balancer can communicate with (and alter the charge rate of) the charger, like the Thunder Power charger and balancers. The most important thing to consider when working with charge rates is if your charger can handle what you want to do.
The next size up in Enerland cells (the company that makes the Flightpower cells) is a 5000mah cell. This cell is a true powerhouse, it can sustain 30C currents (150amps!) pretty well, but is rated at 20C continuous. However, this cell is priced around $60 PER cell. I think for you Enerland cells are out of the picture (for cost vs. capacity).
The True RC cells have a graph that can be seen here:
http://www.rcgroups.com/forums/attac...hmentid=806053
Don't worry about the ending of the 6C (green) curve, that was just when the temperature cutoff cut in on the guy's testing equipment.
This cell is about a 8C continuous cell, but is capable of doing 10C for most of the discharge. There's no way that your car is going to be pulling 80amps average, so the discharge rate is fine.
06.14.2006, 01:59 AM
Just chipping in w/ my $.02
I have been using the TrueRC 8000mah 3s and 2s wired in series for 5s on my erevo for the last few weeks. I gotta say, for the $... they are great. I charge them up and run for 45 minutes bashing around the bmx track. I ususlly have broken something before the batts were dead. The packs have never gotten even more than just slightly warm. Even running back and forth full throttle in a grass field. (the esc did though..lol)
I must say though... Charging them takes a while, at least with my charger. I'm using a superbrain 977. It will charge MiMH at 5A, but the Lipos it caps the 3s @ 3A and the 2S @ 2.5A. At that charge rate it takes a couple hours. to completely charge them. I'm thinking about getting the new Thuderpower charger. It is supposed to go up to 10A for Lipos. That would cover the 1C and then some. I'm also waiting to see what the new SUperbrain 989 is gonna be like. Is supposed to charge up to 8A on Lipos as well, and with the aded bonus of AC/DC right out of the box. But... These chargers only have 1 output, so to do both packs its 2 hours of charging time anyway. I can plug up and charge both batts at the same time on the 977.
Sorry for the ramble.... I kinda got off point.
Summary: Good batts...:027: Long runtime...:027: Good power.....:027: Low price...:027: how can that be bad?
EDIT: And dan is a pretty decent dude as well.
to make it...
or break it...
Silent...But Deadly
COOKIES!
06.14.2006, 10:53 AM
So why can't you charge the 8000mAh at 8amps? Isn't 1c the capacity divided by 1000 or something? So 3300s, 1c is 3.3amps?
06.14.2006, 06:40 PM
His charger in limited in how many amps it can put out. 1C is equal to the capacity in Ah. Ah (Amp-hour) = mAh (milliamp-hour) / 1000.
06.14.2006, 11:38 PM
Metalman is right. Its not the packs. Its the Chargers limitation. The packs can take 8A charge rate. My charger cant deliver more than 3A for lipo.
Sorry. didnt mean to confuse you.:002:
to make it...
or break it...
Silent...But Deadly
COOKIES!
06.15.2006, 07:14 AM
So these 8000mAh True RC ones are like 8c discharge? Is that abit low?
06.15.2006, 08:42 AM
Originally Posted by MetalMan
His charger in limited in how many amps it can put out. 1C is equal to the capacity in Ah. Ah (Amp-hour) = mAh (milliamp-hour) x 1000.
I believe you meant to say Ah = mAh / 1000
06.15.2006, 09:02 AM
There is no such thing as a "low" C rate. Since these cells can handle 32amps continuously, and higher in burst, that's not too bad as long as you use a 2p setup for 8000mah and 64amps continuous.
COOKIES!
06.15.2006, 01:03 PM
So will the C rating be fine with a 7XL? Running 5s2p/6s2p 8000mAh packs?
Still unsure what all the jargon means. :D
06.15.2006, 02:04 PM
I'd worry about using 6s Lipo with a 7XL (for the motor's sake). Otherwise, that setup should be more than okay.
06.15.2006, 03:02 PM
[QUOTE=jhautz]Just chipping in w/ my $.02
But... These chargers only have 1 output, so to do both packs its 2 hours of charging time anyway. I can plug up and charge both batts at the same time on the 977.[QUOTE/]
You can make a Y connector and charge them in series so it will only take 1 hour.
06.15.2006, 03:04 PM
COOKIES!
06.16.2006, 01:39 PM
Which Lipos would you go for? I like the Flightpower ones but their capacity is abit low and I like the TrueRc ones but their protection and build quality looks low, how they use tape around them and all.
06.16.2006, 02:11 PM
I would go for the TrueRC ones.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
