06.21.2006, 09:25 AM
Originally Posted by Tom F
I know what you're saying, BrianG. I think that must be the case. on the temperature thing though, you'd be surprised - manufacturers will run these devices very hot indeed. Try touching the power regulators on your computer mainboard - sometimes they can be extremely hot.
Well, that may be true normally, but I am extremely anal about excess heat on any electronic component. IMO, anything that is 20-25 degrees F over ambient (or a max of ~120 degrees F) does not have sufficient cooling. Anything over that gets added heatsinks, active cooling, etc.
Tom F
RC-Monster on a Budget
06.21.2006, 11:34 AM
If i had a choice i'd run stuff at a max of about 60C, but it costs too much for manufacturers to bother. It's cheaper to deal with a few failures than to put a $1 heatsink on something that will be sold by the thousand or even the million.
To keep say 12 transistors running at about 40F over ambient, if there was a total dissipation of 240W, you would need a heatsink with a thermal resistance of 0.1c/w temperature rise. Passive cooling of that efficiency is amazingly expensive (a sink that big would be enourmous)
They have to have high heat tollerances, because in an application such as a small mobile device that has to handle a lot of current (such as a brushless ESC), yet be compact and lightweight, it's not always possible to keep it small and also running cool. The total thermal resistance of a sink on a brushless controller might be 2c/w if you were lucky, so if you dissipate 40W on it, it will be 80C over ambient!
http://img513.imageshack.us/img513/3880/dscn1559dp5.jpg
Brushless - How fast do you wanna go today?
  Send a message via MSN to Tom F
06.21.2006, 12:15 PM
I agree, and that's why all my power projects are huge and clunky from heavy duty heatsinks and/or fans. After running my Quark 125B for a while it got too hot for my taste, so I thermal epoxied (Arctic Silver) a secondary heatsink. It doesn't look good, but lowers the temps to more reasonable levels (to me).
