RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.10.2005, 09:50 PM
I usually find a way to mount it within the wires size that is available. I have never had to add wire(in fact, I usually take wire away). You way be able to solder the controller wires to the motor at a right angle (90 degrees) and end up needing less wire than you think. Then, cover the connections with liquid electrical tape (can't heat shrink 90 degree corners).
