Sneeck
RC-Monster Custom
Sneeck's Avatar
06.22.2006, 03:04 PM
Cause the motor will rev very high. You should keep it in the 35.000 range, this to keep from going to extreme small pinion's to compensate for the high rpm. But it also causes the motor to work hard running allot of rpm, decreasing power and efficiency.
The motor has a rpm/ volt of 2332, multiply this by 19,2 volt's and you get 44774 rpm.
The 9xl has a rpm/ volt of 1853, multiply this by 19,2 volt's and you get 35577 rpm.
  Send a message via MSN to Sneeck
