RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.13.2005, 02:43 PM
Originally posted by supermaxx
Thanks for the reply lipomaxx!
I Heard, also from the dual setup, that you can run stock diffs or robinson gears instead of UE if you put them real good tight in a case, so it won't move and break, is this true?
This is true. I use Maximizer cups inside Integy cases with pretty high power. In the last few years, I have only stripped on set of spider gears (and the diffs were due for a shimming, so it was my own fault). A properly set up diff inside a flex-free case will stand up to some abuse.
