Ventman
01.21.2005, 05:16 PM
Alright, here's my procedure breakdown:
1. Connect the ESC to the motor and Rx ((CHECK))
2. Remove Red jumper block ((CHECK))
3. Connect main power up ((CHECK))
4. Wait for the first beep for setting neutral position ((just sits there))
Yes, I had to cut away some of the shrink to get to the BEC jumper. I've tried the above procedure with an Rx pack as well as adding 'turning on the Rx pack' between steps 2 and 3.
I'm still not quite sure this is the right controler for the application I have, I've been hearing the higher the cells you put into it, the less of a cogging problem it seems to have, however the RS4 MT is restricted to 6 cells in stick or saddle config, and I really don't feel like tearing up my stick packs and modding a discontinued kit. Might just have to try another controler better suited for a low cell count.
 Send a message via ICQ to Ventman
