Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Darren
07.17.2006, 06:45 AM
Originally Posted by BrianG
At 40T, that's an 18T pinion, which aren't available for Mod 1.
Mike sells 18t Mod 1 pinions, and they're in stock.
07.17.2006, 11:00 AM
Aah, now I see; they weren't in numerical order. My bad. So it looks like I'll be going with mod 1 gearing., as long as the motor I select uses a 5mm bore. That negates the use of the Mamba Max systems because there are no 1.8" bore Mod1 pinions above 15T, and I would need 18T. I also have to watch the size of the gears to make sure they are big enough so the motor will clear the tranny.
Edit I took so long to post my response that two oither posts came in! I guess I'll have to figure out what motor/ESC I'm gonna use and then pick my gearing based on that. Once I decide, I might have to ask Mike if he can make/get the right size. Thanks guys.
