squeeforever
squeeforever's Avatar
08.20.2006, 08:33 PM
First off, welcome to the forums! I would definately choose the Feigao XL C motor over a Novak. If you can swing it, a Quark 125B is the best, but a 9920 will certainly do. CVD's, or the 3.3 setup is a must, and a UBEC is a necessity above 12 cells. Aluminum diff cups and cases are a good investment, but the FLM hybrids with Hot Bodies Lightning diffs are the way to go. A little more, but you never have to worry abou them again.
Edit: Mike, why would you choose the Wanderer? It cost more with the heatsink, and just as much without...No differences what so ever other than the heatsink and the screwed on endbell.
