stampy
stampy's Avatar
08.30.2006, 11:02 AM
Try to make sure your set screws and cups are on the shaft right.
Some times you can get it tight but it is twisted a touch.
Make sure the set screws are on the hole where the stock pin goes thru.
Put a drop in the hole as well on the set screw. It holds a little better than way.
mine dosent have a hole threw it:032:. ok i was using the blue mip stuff ill try red and ill replace the set screews with new ones hopfully that will work tnx guys:dft009:
