aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.30.2006, 01:53 PM
I tried enabling ABS, but it helped a little bit... Don't you use the MGM?.. I was reading something about the esc controlling the motor to match the escs rpm... I have this option disabled but it still slows the motor down.. it really kills the gears and spins my truck around when it does this. especially with that big motor...
Gustav
Gustav's Avatar
08.30.2006, 05:22 PM
It sounds like you need to send them for the software updates.
I have version 2.31 on mine so i'm going to send it for the update.
The problem i have is not when lifting off (i have drag brake off,and freewheel on).The problem is it brakes when you blip the throttle/apply a light throttle whilst coasting.It seems to try to reduce the motor RPMs to the level of the throttle input,so if you apply a light throttle it will brake violently.
If you set the range of throttle neutral zone high it helps.I use a one-way bearing to get around the problem in the mean time,it's the only way it can be used with a lehner motor.
