Serum
Serum's Avatar
09.02.2006, 01:35 PM
I took am aluminum case 15 or 20W resistor, which i mounted inside the case, i don't remember what value i took, it think it was a 22 Ohm, which stayed cool enough in the airflow of the PS. (6.5W wasted energy, small price to pay for a cheap PS.. :) It's not really needed to get the formula, eversince it's about 12 - 13V that's used.
You can determine if you need a resistor by measuring the voltage. if the voltage differs much from unloaded/loaded, a resistor might be needed. In some cases the charger doesn't want to start if the voltage is too low.
09.02.2006, 01:44 PM
Agreed. I just don't want people who really don't know about that kind of thing at all to slap a resistor with a resistance value too high or too low and wonder why it's not working, or think the supply is bad when/if the resistor blows, or the supply shuts down for too much current. You obviously knew what you were doing.
Measuring the unloaded/loaded voltage can work, but if a load is needed, usually only one power rail contains the regulation feedback coil. It depends on the design of the PS for which rail this is.
BTW: I'm not trying to argue with you, I am merely explaining this for the sake of less electrically-minded forum members out there. :)
