09.13.2006, 04:29 PM
If you're running 20v to a small fan, which probably pulls no more than 300mA (most likely ~200mA), you could use a 12v regulator. Power dissipation will only be 2.4W or less. It would need a heatsink though.
Using the 5v fan is fine on 6v though. If you were really concerned about overvolting it, just run a diode in series. The 0.6v-0.7v drop will bring the voltage even closer to 5v.
Finnster
KillaHurtz
Finnster's Avatar
09.14.2006, 07:47 PM
Yeah I thought about doing that if the 25mm doesn't do a good enuf job, but I wasn't excited about having to add more clutter, plus I wasn't sure at what point I'd need a HS.
The good news is I ran 3 pairs of packs yesterday and the temps on the esc stayed low. Max temp was less than 125 on the HS (generally in 1teens tho) and max of 135ish on the caps. The drawback to the 25mm is its not blowing on the caps so they are running hotter than before, but still well in spec. The bad news was the motor peaked at 165+ after ~45 mins of hard running on the dirt (jumps, high speed runs, powerslides, climbing and other bashing goodness.) The HS was only getting to ~125, so I'm worried poor contact may actually be insulating the motor some. Had a blast tho. :)
Strangely, the rear steel output shaft for the tranny got to ~165. :013: I was careful to have the drivetrain freespinning when I built it, and had to do a little chassis trimming for the shafts. I did notice the shaft moving a bit under high throttle, so I'm thinking a bearing is busted. I do not see any signs of wear between the chassis and the driveshaft. Hopefully addressing these two issues will bring down the heat some, else I may be looking at a Neu sooner than later..
