Serum
Serum's Avatar
09.17.2006, 12:55 PM
that's wicked..
JB3231
JB3231's Avatar
09.17.2006, 05:43 PM
Both guys in the video are running 5700 Mamba Max's. The second guy is supposed to be running a 8 cell Nimh. Wouldn't the 3S on the 5700 be a little faster than the second car.
8 cell Nimh 9.6 9.6V
3S Li Po 11.1 V
Mine:
2007 Grizzly 700 EPS EFI
Sons:
BL E-Maxx
4S MA 4000 Lipo/MM ESC
Feigao 9XL 22/54 gearing
Gmaxx single speed
Brushless Revo under construction
cemetery gates
09.17.2006, 07:52 PM
3S Li Po 11.1 V
um....yeah
but the mm 4600 on a 4s would be the fastest...............
JB3231
JB3231's Avatar
09.18.2006, 07:49 PM
I ordered the 5700 Mamba Max motor/contoller, 3S Li-Po 4000 Mah Maxxamps battery, Spektrum tx/rx, and charger yesterday.
I can't figure out if I should put it in a B4 or TC4. The expansion joints in the driveway and cul-de-sac may be a little rough for the touring car. Has anyone bashed with a touring car? The accelaration and handling should be insane.
Mine:
Sons:
BL E-Maxx
Gmaxx single speed
cemetery gates
09.18.2006, 08:03 PM
fine don't listen to me! j/k
nice man should be fast! i would go with the B4 myself................
JB3231
JB3231's Avatar
09.18.2006, 08:06 PM
I didn't want to mess with the BEC and extra cost right now. Seems a little simpler this way and I should get more than enough out of this setup.
Mine:
Sons:
BL E-Maxx
Gmaxx single speed
JB3231
JB3231's Avatar
09.18.2006, 09:25 PM
Will the 3S fit in a MR-4BX ? The car is setup for side by side.
Mine:
Sons:
BL E-Maxx
Gmaxx single speed
squeeforever
squeeforever's Avatar
09.18.2006, 09:28 PM
There are only a few cells that fit the bill for SxS.
JB3231
JB3231's Avatar
09.18.2006, 09:34 PM
MaxAmps Lipoly 4000mah 3S 11.1V Pack
4000mah Capacity
11.1 Volts
44mm X 132mm X 20mm
Rated at 48 Amp Constant Discharge(12C)
Rated at 64 Amp Burst for 10 seconds(16C)
255 grams
Mine:
Sons:
BL E-Maxx
Gmaxx single speed
09.18.2006, 10:06 PM
What's the question?
JB3231
JB3231's Avatar
09.18.2006, 11:12 PM
Has anyone tried this balancer? And does it work pretty well?
"Great Planes ElectriFly Equinox LiPo Cell Balancer 1-5"
I have this charger coming in the mail:
"Multiplex Multicharger LN-5014 ~ 92531"
And this battery coming from MaxxAmps:
Lithium Polymer Battery RC Car 4000mah 3S 11.1V Pack
Mine:
Sons:
BL E-Maxx
Gmaxx single speed
squeeforever
09.18.2006, 11:14 PM
The Equinox is the same thing as a Hyperion LBA6. Metalman has the Equinox version and I'm pretty sure he likes his...
MetalMan
MetalMan's Avatar
09.19.2006, 07:28 PM
I wish I would have gotten the LBA6 instead of the Equinox. The reason is that the Equinox uses a particular type of taps that many batteries don't use. The LBA6 uses the Hyperion/Polyquest, which are more popular. I ended up just buying the LBA6 adapters to use Hyperion taps on my Equinox, so the $10 I saved by getting the Equinox was not worth it.
JB3231
JB3231's Avatar
09.25.2006, 09:57 PM
Originally Posted by cemetery gates
yes the 4600 is faster on 4s http://www.rc-monster.com/proddetail...MM_4600&cat=20
ans here is the ubec
http://www.rc-monster.com/proddetail...=6vubec&cat=21
you can safely run 4s on the mamba max with a UBEC, but i believe you will void the warranty.
charger maybe?
http://www.rc-monster.com/proddetail...531lipocharger
not sure about a balancer.......
I just noticed the charger is DC input only. Is there a cheap power supply I can use for it? I can stick a car battery on the work bench and keep recharging it, but what a pain.
Mine:
Sons:
BL E-Maxx
Gmaxx single speed
squeeforever
09.25.2006, 10:54 PM
You can convert a cheap PC power supply...or buy my Novak :D.
