Go Back   RC-Monster Forums > Support Forums > General Nitro
squeeforever
squeeforever's Avatar
09.21.2006, 10:12 PM
It shouldn't....
rchippie
rchippie's Avatar
10.10.2006, 05:37 PM
What i do sinice i dont have a gear puller here is what i do . First you take off the clutch bell & clutch shoes & clutch nut. Then you turn the motor over & put the crank shaft on something solid. Then i take a adjustable wrench & adjust it to fit the back side of the flywheel & tap both sides with a hammer & the flywheel pops right off. I hope this helps :027: .
REAL MEN RUN BRUSHLESS
tallyram
tallyram's Avatar
10.10.2006, 10:46 PM
thanks hippie, but i already bought a flywheel puller. it works really well!
  Send a message via AIM to tallyram
rchippie
rchippie's Avatar
10.12.2006, 11:25 PM
You did the right thing. You should always use the right tool for the job, so you dont screw anything up .
