Cell Pro LVC -
10.01.2006, 11:55 AM
I need help wiring an adaptor for this to go onto 2 2s2p, hey Metal, can you do a grovvy diagram on how to wire it for series cut off? thanks!
10.01.2006, 12:21 PM
Well, here is a diagram. (not as funky as the ones Metal creates..LOL)
You need to wire the cellpro inline between the speedo and the receiver.
10.01.2006, 01:21 PM
The Cellpro monitors each cell, so it has to work through the taps.
I can draw up a diagram, but I have to rush out now, so I'll do it when I get back home.
10.01.2006, 01:31 PM
I'm loosing it.
10.01.2006, 01:44 PM
Originally Posted by Serum
I'm loosing it.
Big time...
10.01.2006, 01:54 PM
Sounds good. That's what i thought as far as the taps. Also, the balancer adaptor i made for the 4s is not working, but it makes no sense cuz i did it just like the 5s without one wire is all...what the deal? thanks guys!
10.01.2006, 03:32 PM
I expected a bit of support Squee.. This is not helping..
10.01.2006, 08:53 PM
I updated the other thread with the correct wiring diagram for the LBA6.
To wire the Cellpro LVC, you'll need to connect the same wires to it as you would to the LBA6 in the same order, except for the outer two wires (the ones that branch off) that aren't used. I don't know which connector (if any) is on the Cellpro, but if it's a 5-pin connector, then you're going to have to make another adapter.
10.02.2006, 09:18 AM
Yes it's a five pin. I wired it too the same as the adaptor, but that too is not working just like the 4s balancer adaptor. When i plug the lvc up, it won't run, if i disconnect the lvc, i can get it to go.
10.02.2006, 09:30 AM
Could you by any chance post a pic of how you have it wired up, just so we can see if there are any faults?
10.02.2006, 09:32 AM
Let me see...they may be online at home, not sure if i saved them to photo bucket or not...
i can post pics tonight, they are not on my work computer so....sorry. But basically, with the lvc, there is one red, then 3-4 white, then one black. So i connected the black and one white, then the red and whites to the other side..two plugs, one for each batt pack. i made sure to hook pos to pos, and neg to neg in series as well, then that adaptor goes to the lvc. i plugged the esc into the lvc, then the lvc into the rx...
10.02.2006, 11:57 AM
thanks for all your supportive words squee
10.02.2006, 12:03 PM
Serum...Are you talking to Squee? Or Me!?
10.02.2006, 12:27 PM
well, my post says 'squee'
10.02.2006, 08:43 PM
I'm sorry...I shoulda been more supportive...:frown:
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
