smhertzog
Breaker of all that is Stock
smhertzog's Avatar
10.03.2006, 07:41 AM
Originally Posted by pb4ugo
So after letting it sit for a couple months while I was busy, I finally test ran my CRT with 160/24 and Lehner 1950 7t on 6s lipo. It was running backwards, but I wanted to run so I just dealt with it for two passes up and down my street. Ran like a bat out of hell. Brought it in to switch the two wires on the motor to fix the backwards running. Turned it back on, and nothing.
I re-did the programming, still nothing. The controller would blink it's LEDs for the programming sequence, but instead of a motor beep sound, I would hear a pop sound. Repeated this numerous times and switched the motor wires back just to see. Same results each time. I noticed one of the external caps had broken next to it's mount on the board, so I soldered it back on. Still nothing.
I hooked up the Lehner to a Mtroniks I have, and it worked fine. So i guess the question at hand is if any of you can think of something I missed. Or how is MGM warranty? Slow? Do I send it back to Mike or directly to MGM?
The pop sound is not a good sign. Call Mike he will most likely have you send it to him, but call him anyway.
Never fight an ugly man..... he has nothing to loose
pb4ugo
10.25.2006, 11:50 PM
Now I'm pissed. Tried it again tonight after it passed my visual inspection. A little puff of smoke from the motor output side was the result of powering up. A $365 controller that worked for 30 seconds.
I went 6s also expecting to use this controller. Are the Quarks still experiencing difficulty on 6s?
Now does anyone know the service situation with MGM? Still taking multiple months?
