Whats better?
squeeforever
squeeforever's Avatar
Whats better? - 10.08.2006, 05:19 PM
Whats better for hex wrenches? Titanium Nitride coated shafts or spring steel. I'm not really sure...I would say spring steel since the TiNi is only a coating that will wear off...
Darren
10.08.2006, 05:28 PM
I have some hardened steel ones and they're not showing signs of wear after like 6 months.
My friend has TiNi coated Ofna ones, they've wore down quite a bit in a shorter space of itme.
crazyjr
crazyjr's Avatar
10.08.2006, 05:37 PM
I got the integy set with ti ni shafts, had them for a few months and no wear issues
Darren
10.08.2006, 05:40 PM
Seems like Ofna and Integy have different views on what TiNi is.
I'm surprised Ofna's appear second best to Integy.
No matter what hex drivers you buy, they beat the pants off allen keys! I cant even use them now, its like going back in time.
Squee, do you have any specific ones in mind?
Serum
Serum's Avatar
10.08.2006, 05:42 PM
Squee, i bought a set of the PB's (swiss perfection)
I like the Hudy as well. they are not that expensive.
The most used types are 2 and 2.5mm the 1.5 is only used for setscrews, and the 3 is used for M4 cylinder heads
squeeforever
10.08.2006, 06:22 PM
Well I was thinking the Integy. They have a set of 7 spring steel purple ones that I like :D. I like the price too. I need 1.5, 2.0, 2.5, and 3.0. I have some M5 screws with 3mm heads on my truck, so thats a must. I would say the 2.0 isn't as common as some since Integy doesn't include it in ALOT of there sets. I did buy some Thunder Tiger ones (set of 4) that seemed nice...That was before I broke the tip off of the 2.0, and wore down the others in a matter of no time. Yea, I know, I could grind down the tip, but only a few times since the allen part is only like 1/8th inch...
Serum, got a linke to the PB ones?
Serum
Serum's Avatar
10.09.2006, 01:20 AM
http://www.pbswisstools.com/en/index.asp
2 mm is most common!! it's used for buttonhead and countersunk M3 screws.
neweuser
neweuser's Avatar
10.09.2006, 09:10 AM
I have a set of Integy's TI's and love them. I use my wrenches all the time. The 2.5 or something is what I use the most, had it for a few months with no wear.
squeeforever
10.09.2006, 10:06 AM
Yea, it is pretty common on certain vehicals, mainly Traxxas. Anywho, I wonder why they don't include it in alot of there metric sets :032:.
Rcbros
Rcbros's Avatar
10.09.2006, 11:19 AM
I've had 2 sets of integys. They fit great but I've broken alot of tips. Dynamites are alittle better. Don't seem to break as easy and have a better fit.
But the best so far are the MIP thorp drivers.
  Send a message via Yahoo to Rcbros Send a message via AIM to Rcbros
skellyo
skellyo's Avatar
10.09.2006, 01:31 PM
I've been using the Associated Factory Team set ( these: http://www2.towerhobbies.com/cgi-bin...&I=LXJTR0&P=ML ) for a couple of months with no complaints.
crazyjr
crazyjr's Avatar
10.09.2006, 01:44 PM
except for OS small blocks, i've had two and they use 2mm screws in the head
Serum
Serum's Avatar
10.09.2006, 01:48 PM
yah, what do you mean?
i said;
the ones most used are 2 and 2.5
the 1.5 is used mostly for setscrews (and M2 cylinderhead hexes)
and the 3 is used for the M4 cylinder hexheads.
I didn't meant cylinder cooling heads, i meant cylinderhead hex screws.
JThiessen
JThiessen's Avatar
10.09.2006, 04:13 PM
IMHO, you'd be better off purchasing tools from a company that makes tools (Snap-on, Craftsman, etc) than an RC company that purchases and re-badges them.
A coating (TiNi), is only as good as the material underneath it. Thats why some guys with with the same coating, from diff. manufactures, will have different results. Coatings are also only good in wear situations, which most tools are not used in. You want a good through hardened steel.
neweuser
neweuser's Avatar
10.09.2006, 04:18 PM
Well. I can say, for the money, I lvoe my integy. Not that Integy makes good product all the time, but I really like to hex drivers. They have lasted and i love'em. No wear at all after a few months! And for the price, you can't beat it. And that's my 2 cents...
