squeeforever
squeeforever's Avatar
10.23.2006, 11:28 PM
Ok, well I thought yall might like an update. Today I got my last items needed...or so I thought...Now I need a new motor mount/diff holder since the batteries hit the stocker. I'm gonna lower it a little less than 1cm so I can use a Ofna 51T spur instead of the 65T (would hit the batteries as well) and I'm gonna put the motor in the center between the braces. The CG will remain the same actually and will balance the truck better. I think it should be a better setup...I just can't imagine why they didn't do the same...Another thing wrong with the stock is that the shoulder that holds the bearing is less than 1mm thick (it's more like .5mm) and on the back holder/motor mount was starting to crack...So I'm gonna have to make it thicker as well...Not biggie really...Just puts me back a little on running it. I should have pictures soon though, with or without the motor and diff in it...I also got all the axles converted to 8mm and have Dace hubs, etc. I also did a few other mods...as well as a new shell and a new wing, etc.
