10.27.2006, 11:12 PM
Assuming the ESC is OK; how does the failsafe on the Spektrum module get set? On the full system, you set it when binding. Could it be set to some throttle amount when the ESC is shut off? To test, put the steering into the throttle channel on the Rx and then shut off the transmitter. If the steering goes one way, then it's the failsafe on the Rx.
BTW: I think a harddrive jumper will fit.
