10.29.2006, 10:28 PM
Originally Posted by carlog80
so ur having problems with the combo? or with your reciever? what do u mean ill need a battery pack or ubec? I'm sorry u'll have to excuse me cause i really dont know anything about brushless systems.
The BEC in just about every ESC I can think of is just a linear voltage regulator. This means there can be a lot of heat dissipated on the regulator, and gets worse the more cells you use and the more servos you use. If you are running anything more than 2s (or 6-8 cells) I would use a BEC. Some people use the ESC BEC up to 12 cells, but I am a bit anal about such things. The excess heat from the regulator will heat up the heatsink for no reason.
A UBEC is a digital device, meaning it uses pulse-width modulation to regulate the main battery voltage down to 5v or 6v for the servos. These are MUCH more efficient and hardly heat up at all.
If you are REALLY interested, here 's an example:
Linear BEC (found in ESCs):
dissipated_power = ( main_batt_voltage - 6v ) * servo_current
Let's say you are running 12 cells and are running a servo that draws an average of 1A at 6v. The heat the ESC heatsink has to dissipate is; ((12cells * 1.2v) - 6v ) * 1A = 8.4 watts. That is quite a bit believe it or not. This equates to about 41% efficiency (output wattage / input wattage). Also, 1A will be drawn from the main batteries just for the servo (even though it is only using 6v), which reduces runtime. At 16 cells with this same 1A servo, efficiency would be down to 31% and heat up more (13.2 watts).
A digital UBEC (and they almost always are) runs between 80%-90% efficiency. So, if the servo draws 1A at 6v, the UBEC only dissipates about 1W or less of power (at 85% efficiency) and draws only ~.4A from the main batteries. And with more cells, the UBEC will draw less current from the batteries yet still be just as efficient or more.
This example is a little off because a servo won't draw 1A all the time, but you get the point.
