Lipo - Charging and balancing - HELP -
10.30.2006, 03:55 PM
I have some 2s2p 8000 mah lipo´s from Maxamps - I´m not sure of how many amps they should be charged with. The charger can do up to 5 amps. Does anyone know ????
I also have a balancer - Apache 505 from Maxamps - but i´m not sure how to connect it. If I just connect it to the plug on the battery if shows error. Do I have to charge trough the balancer ??
The charger is a Swallow 2 digital peak charger.
Please help
COOKIES!
10.30.2006, 04:08 PM
You can charge at a rate of "1C" which will be 8amps, since your charger can only do upto 5amps. You can charge at 5amps.
1C = 8000mAh / 1000 = 8amps
...for example if you had 3700mAh batteries it would be:
1C = 3700mAh / 1000 = 3.7amps.
I believe that is correct. :)
RC-Monster Cult Member
10.30.2006, 04:49 PM
Is that you JJ?
10.30.2006, 05:00 PM
Yea, Nick, that is correct. Welcome to the forums, by the way.
10.30.2006, 09:08 PM
You don't have to charge through the balancer, and shouldn't at 5amps. Do you have a picture of the balancer connected to the battery? It's very possible that the balance connectors are wired wrong (not your fault).
10.31.2006, 07:07 AM
10.31.2006, 07:08 AM
This is how I wired it up. And when I do this the error led lights
10.31.2006, 07:30 PM
Is it blinking, or is it solid? If it's solid, that just means that it's balanced :).
11.01.2006, 01:48 PM
It is solid - but it is the error led that lights , does that mean that the batterys are balanced ?? ( it could make sence it the forst time the batterys are charged ??
KillaHurtz
11.01.2006, 04:46 PM
Just got this balancer as well, a solid green means the pack is doen charging and/or balanced.
A flashing green means uh-oh.
11.01.2006, 10:32 PM
Yeah, flashing green LED means error. Notice that next to the word Error says "Check". That means that the cell voltages are in "check" :005: (balanced).
KillaHurtz
11.02.2006, 12:18 AM
Hey MM I got a ?
I'm charging thru the balancer (charger only does 2.5A anyway,) and I notice towards the end of the charge the amperage drops very low, ~.1A or so. This is with a Triton.
Is this normal? I'm assuming the cells are nearly charged, and the balancer is just topping of the last cell or two. LMK, :)
11.02.2006, 12:54 AM
I'm not MM, but that's just the end of the constant-voltage stage of the charge and is perfectly normal.
11.02.2006, 01:53 AM
What he said :).
11.02.2006, 04:28 PM
Well I learned something again today :030: I will see what it says I have used and charged the battery´s a few times. And return if its the same :eek:
Thank you very much for your help
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
