11.03.2006, 10:24 PM
Well, you could do the disconnect thing, or install a bypass switch. To my knowledge, all a LVC does is interrupt the throttle signal wire and sends a neutral signal to the ESC instead. You could wire a switch on this one wire and bypass the whole LVC.
