hot bodies ring and pinion part #s
strodedawg
hot bodies ring and pinion part #s - 11.14.2006, 09:40 AM
hey,
what are the part numbers for the hot bodies 10t pinion and 43t ring gear that fit onto the jammin crt diffs? are they hardened? any other mods needed?
thanks for the help
jim
let's build something sick!
Serum
Serum's Avatar
11.14.2006, 10:46 AM
C9009 for the pinion
C9010 for the ringgear
Mike sells the entire diffs as a drop-in
I don't know if it fits.
strodedawg
11.14.2006, 11:17 AM
thanks serum
squeeforever
squeeforever's Avatar
11.14.2006, 05:45 PM
They fit...MacII did the same thing to lower the gear ratio so he could run a Kyosho spur and get rid of the large steel one.
strodedawg
11.15.2006, 07:16 AM
just bought them at the shop, the pinion gear seems way long. the center cvds don not slide all the way on. what did people use to shim the slack? also does anyone know what final drive macII is using on his crt? thnaks for all the help.
slow-stampede
11.16.2006, 11:56 PM
Did you get this to work? I'm thinking about doing the same and want to know what parts/mods are needed.
Cartwheels
11.17.2006, 12:05 AM
Can you grind off some of the shaft on the pinion to make them fit better instead of shimming them.
