aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.19.2006, 11:04 PM
it's hard to say what kind of amp draw the Mamba Max motors take... there's a reason why they made the mamba max esc 100 Amp continuous.... but depends what you want... I like anywhere from 35 to 45K rpms for the motor.... I'd rather use more cells less amps than less cell and more amps..... .. I guess heat's the biggest problem... the motor can only take up to 100 degrees celcius.. "I think"...
but the mamba max 5700 or 4600 would definately be a good choice.... I have to agree with Speedy...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Tom F
RC-Monster on a Budget
11.21.2006, 06:09 AM
Well the draw is 'supposedly' 106A, and the motor is rated for 1000W (which would make sense on a 3S pack under load), although I agree the draw is likely to be substantially higher... especially under startup conditions.
It would be so much easier if they provided more/useful specs with these things!
So i shouldn't try it?
My understanding is that the MM will soft current limit, although i've always found the draw from this can to be insane...even on 6 cells.
Don't want to push it too hard...
I'm saving for an EagleTree...it's getting old having to guess at these things without actually knowing what's going on.
The XXXS G+ is extremely light with extremely low mechanical resistance, which will help reduce the draw, but i don't know how far.
Anyone know under what conditions the current draw ratings are measured? I'm assuming it's not stall, so what is it? Average? At max efficiency?
Edit: I'm not worried about heat. At least not in the motor - but I can see it being a significant problem in the ESC. As i said in my first post, I will be making a switch to the Mamba Max 4600 system ASAP, this is an intermediate thing, mainly out of curiousity ;)
I have a bunch of audio projects that i need to finish first though, so that will have to wait for now :(
http://img513.imageshack.us/img513/3880/dscn1559dp5.jpg
Brushless - How fast do you wanna go today?
  Send a message via MSN to Tom F
