Brushless Lightning project
bemmermazda
Brushless Lightning project - 11.22.2006, 09:03 PM
So i am starting this up to some versions that i have seen that are magnificant. The Truggy will be a Hotbodies Lightning pro-R which. The car comes as a built roller. The system will be a mamba max esc runing a Faegio 9xl. I will use an elevated motor mount to give me the most side room for cells. It will not be lithium. to be able to run more cells i will change placement of the servo and move it to the center. i need help on the motor. i need someone to cut it. but i will design it. so anyone who can do this please let me know. i am hopping for dual 8 side by side cell packs. i hope it gets enough power.
coolhandcountry
coolhandcountry's Avatar
11.22.2006, 09:33 PM
you got it truggy already or plan to get one. I have thought of one of these
myself. 16 cells on a 9xl should work nice. I think lipo would be nice for lighter weight.
Peace!
Country
Help support the
Rc-Monster
Buy here
bemmermazda
11.22.2006, 10:00 PM
yhea, it would be better but i dont hve that kind of budget. so, what can you do?
cemetery gates
11.22.2006, 11:05 PM
Good choice of motor and # of cells; i used this setup with a Quark 125b in my Lightning Pro and it worked really well.
Bye:018:
bemmermazda
11.23.2006, 12:47 AM
sweet. what were you runtimes and speed?
how much is that esc?
bemmermazda
11.23.2006, 12:56 AM
Feigao/Nemesis/Wanderer "XL" Brushless Motor 12 xl
how well would this work in the type of car i am using. i am looking for as fast as i can get. but no more than 65. i also NEED good runtimes.
Serum
Serum's Avatar
11.23.2006, 02:37 AM
the mamba maxx on 16 cells is too much imo.
coolhandcountry
11.23.2006, 08:17 AM
You think the mamba can't handle the 16 cells real well.
Peace!
Country
Help support the
Rc-Monster
Buy here
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
11.23.2006, 11:13 AM
I did a few speed runs with 16 cells and it didnt get any hotter than with 4s lipo orions. But like I said it was just for a few speed runs 16 cells is pushing it. Make absolutely sure you have a BEC if you try it and dont forget to cut the red wire:027: let us know how it works
Never fight an ugly man..... he has nothing to loose
HotnCold
HotnCold's Avatar
11.23.2006, 11:18 AM
And if your gonna be racing - then make the motor mount as low as possible for a low center of gravity - and you might ( depending on the thickness of the motor mount ) wanna think about supporting the back of the motor so that there is no flex up or down.... jmho..... Good Luck
Hows that "Hope and Change" working out for Ya???
cemetery gates
11.23.2006, 11:42 AM
Well, my speed was around 40 or so and i got around 20-25min bashing and around 10min racing.
here is the esc
http://www.rc-monster.com/proddetail...RK_125A&cat=21
you might want to use this heatsink with the Quark 125b
http://www.rc-monster.com/proddetail...=RCM008&cat=21
bemmermazda
11.23.2006, 09:25 PM
i will use a ubec
Brushless Lightning pro-r
bemmermazda
Brushless Lightning pro-r - 11.25.2006, 12:27 AM
I am getting this roller for the holidays and i am planning on doing a conversion. Now i have come to the conclusion for the system, batterys and how i will mount the motor. but i now i hear i need a plastic spur gear, if so which should i use? Also is their someone out their that can cut out a motor mount for me if i buy the aluminum and mark the cuts? obviously for some sort of charge. Where can i get a heatsink for a Feigao xl series motor. i am using the highest one which i believe is the 9xl.
Another thing, can i directly solder the motor to the esc rather than using gold plugs? i know i can but will it be a good idea.
Serum
Serum's Avatar
11.25.2006, 04:28 AM
Will you please stick with opening one topic about this?
the heatsink can be purchased thru Mike, the owner of this forum, check out www.rc-monster.com
the wanderer XL (same as the feigao) comes standard with 5.5 mm gold plugs.
bemmermazda
11.25.2006, 07:48 PM
which one should i go with for maximum power and runtimes on ni-mh cells?motor will be a feigao 9xl
