SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
12.01.2006, 01:17 AM
I saw a picture of a lehner rotor. I didn't get an exact count, but there were a lot of segments each less than 1/8 inch thick.
Area 52 Ranch Raceway
T.R.C.R.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.01.2006, 01:41 AM
Really, hmmm, i wonder what the benefit is going that way. Maybe it gives more consistent magnetic field? I think they have 6 poles total, if i'm not mistaken?
12.01.2006, 11:20 AM
The use of a segmented system reduces magnetic flux "eddy" currents, which are losses. Instead of having large eddy currents in a solid core, you have a bunch of much smaller ones, which apparently is better. Which is the same reason pwer transformers use many plates instead of a solid core. This page explains it.
Using segmented system may also have something to do with reducing hysteresis, but not quite sure on that. It's been a LOONG time since I was in shcool studying magnetic theory.
neweuser
neweuser's Avatar
12.01.2006, 12:30 PM
From my understanding, having more segments would create better efficiency and less resistance with better flow of "eddy" currents. the more segments that are used, the better the conductivity creating less loss? Did I understand that right?
zeropointbug
Z-Pinch racer
12.01.2006, 12:41 PM
BrianG, right, i don't know why i didn't think of that! Duuuh ;) Honeywell has magnetic core that has 10,000's of laminates, then with ton's of force it's squeezed to together with resin. They are suppossed to have super low losses, if you put a NIB magnet inside them, you can't even attract a small nail to stay on it...
Serum, that's what i was think for the Feigao motors...
