12.09.2006, 08:46 PM
I say try it. The LBA10 does have diagnostics that will tell you if it's not wired right. The only thing you'd probably have to watch out for is if you somehow hook the connectors backwards, but the connectors are keyed so that shouldn't be a problem. I'd measure the voltage on the connector though jsut to be sure the wire order is what the LBA expects...
