riceman
RC-Monster Gold
riceman's Avatar
12.13.2006, 12:06 PM
I thought about contacting you with that. that would be cool :027:
There are also a bunch of guys doing LST2 conversions. I have all the ratios already memorized so I don't need them in the calculator pull downs. I do point a few of the guys on the LST forums to your calculator. If you think it worthwhile to add I can try to get exact tooth count on each of the gearing combos. The sad part is a lot of the guys on the LST forums are doing the Fine Design conversions and have no idea what the motor rating is.
12.13.2006, 12:18 PM
If you let me know the LST gear tooth counts, I'll add them. You can either PM them to me or post in the stickied thread. What would be really nice is a seperate tooth count for the diff and each tranny speed. Also, only two tooth counts for each ratio. Sometimes, there are more than two gears in the tranny, so just let me know what they are. I'll just have to convert that to only two "output gear" and "input gear" tooth counts.
