zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.19.2006, 01:27 AM
Do you mean '4600'mAh ? If you want to use A123's in the Baja 5B, then i would say 3 in parallel (6.9Ah) for good solid voltage, and good long runtime as that thing will consume alot of power! As for voltage, i would use something like 12 cells for 40volts. You could then use the BK 36120, this should turn out some serious power. The high voltage should be more efficient and easier on the controller, and motor. You will prob want to get a high turn motor then, i have no idea what kind of trans this thing has, so which turn you get will have to be determined once you buy it, or if someone else knows.
This thing sure would turn heads, literally twisting your head around as it zooms past.
