Sylvester
Sylvester's Avatar
01.07.2007, 09:56 PM
Ive learned 1 important thing about rc, take your time with projects and do it right the first time. Less pain in the end by possibly ruining something, its also a bit more work , too.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
01.07.2007, 10:14 PM
I have similar battery setup as yours and recommend putting some kind of angle pieces on the ends to keep the batteries from shift front-to-back. Even with straps, the batteries will shift enough to possibly interfere with the suspension arms.
Also, it looks like you are using round-head screws for the battery tray. If the metal isn't thick enough to use countersunk screws, I'd use fairly thick padding to keep those screw heads from wearing through the battery insulation and shorting them out.
Mike.L
Mike.L's Avatar
01.07.2007, 10:21 PM
i bet that for some, doing a conversion wouldnt be done as well as we would expected..
yea dom if you still had a chance to do a revo conversion i bet it would be sweet!:027:
  Send a message via MSN to Mike.L
entjoles
01.07.2007, 10:29 PM
yeah the battery tray will be padded and battery secured with some sort of strap or zip tie to see what works and what costs more money
entjoles
01.07.2007, 10:31 PM
what do you think of the novak 4.5, i dont want to spend to much in case it doesnt work out
