smhertzog
Breaker of all that is Stock
smhertzog's Avatar
01.18.2007, 06:04 PM
:018: :018:
Originally Posted by Joe Ford
Fans aren't needed...we designed the controller to run without them...if you thermal the controller you're either geared improperly or there's something wrong with the controller.
I'm running a 7xl on 4s lipo in my 9.25lb Gorillamaxx and all the body holes in the world won't keep it cool after a 15min race. My alternatives are gear it down I need all the speed I got slower is not an option, cooler motor (9xl) $100 which will really slow it down, higher efficiency motor $300 OK till it gets 90 outside, lighten my truck I wont even go there, increase volts via 6slipo - then I would have to get a new motor battery and controller $500 + added weight. Or put on a $5 fan you do the math. I could make my truck much slower (9xl) or stick a whole lot of cash into something that might run a little cooler until summer comes anyway. There are no options that compare to a $5 fan. I'll make you a deal you release the Monster Max and I'll stop running a Mamba Max with a fan.:018:
You have great products, I own three Mamba25\Max controllers. Keep up the good work :027: and leave my fan alone:018: :018:
Never fight an ugly man..... he has nothing to loose
neweuser
neweuser's Avatar
01.18.2007, 06:08 PM
Originally Posted by smhertzog
:018: :018:
I think an 8xl geared right can be just as fast and give you better run times as well as be a cooler set up.
smhertzog
smhertzog's Avatar
01.18.2007, 06:21 PM
I'd have to find a 23 tooth Mod1 pinion plus it would still end up costing me $125 compared to $5. A little longer run time would be nice though.
neweuser
neweuser's Avatar
01.18.2007, 06:29 PM
I think 23/51 would be over geared. But as you stated, $5.00! LOL
smhertzog
smhertzog's Avatar
01.18.2007, 07:26 PM
I'm running a 20\40 on a slippernatural. It gets me just under 40mph, my track has three 30 yard long straightaways so I need some good topend. This is another reason my system gets hot. On a regular track I havent gotten over 90f with the fan. I've gotten up to 140f on my track im pretty sure that would be enough to overheat without a fan. Besides running it at 100f instead of 200f has to be better for the controller.
Procharged5.0
Procharged5.0's Avatar
01.18.2007, 07:32 PM
No question about that!
btw, any pics of that track???
smhertzog
smhertzog's Avatar
01.18.2007, 07:37 PM
This is just after I got it done it has differnet jumps now.
http://www.rc-monster.com/forum/atta...2&d=1151156718
