Why would you need two motors? Aren't there motors out there with shafts on both ends?
I don't honestly know.My exposure to outrunners is from the aircraft realm and none that I can think of have shafts exiting both ends long enough to couple to.???
Of the motors I saw with a front and rear shaft they looked too small IMHO...plus how is the lack of a center diff going to act on the now solid motor shaft connecting both front and rear driveshafts ?? Won't that be a source of great torque stress along the common shaft when the two axles try to turn at different speeds in a corner for instance ??
you guys think the hyperions are suited for cars?
thanks, mike.:D
Was there a time before I went brushless when Hyperion wasn't the best batt around , man, i can't remember a time before high quality lipos came along!--Josh
