01.27.2007, 11:43 PM
10 cells NiMh mode, set to a 15 mv/cell peak detection (so it won't cut out). The capacity value is rather arbitrary, but I set it to 9900mah.
The ICE can't put out the voltage to do 10s1p, so I charge it as 5s2p (the same way it's configured when I run it in my Revo).
Another possibility is the Astroflight 109 charger. Soon there's supposed to be an update for it that will allow you to charge A123 cells. Right now there's a hack shown on another forum that will let you charge the cells on the AF109. Recently I also got a 109, so I will try the hack on it.
Where did you hear about a different A123 charger?
