crazyjr
crazyjr's Avatar
01.29.2007, 01:32 PM
E-revolution, with a 7xl, 4s lipo will get you good speed, My Gmaxx is running a 7XL, MM and 5s with 13/40 and a slipperential (equivilent to a 13/51 strobe setup on an Emaxx transmission) and it runs in the 40's, $s lipo's and a 15 tooth pinion should be good for mid to upper 30's easy. I'll test the 4s with current gearing and see how fast some time today and report back
E-Revolution
01.29.2007, 01:47 PM
What motor is it what you have? What motor is good for my e-revo if i have revo 3.3 chassis and e-maxx transmission? And again, is that: http://www.rc-monster.com/proddetail...P80003s&cat=18 good lipo for my e-revo? I think that 11.1v 8000mAh lipo is enough. If is not enough, what is enough:007:? With MM can use only 6-12 NiCad/NiMH or 2-3s LiPo. <---This mean this lipo what i show is enough, if im not wrong:032:
neweuser
neweuser's Avatar
01.29.2007, 02:04 PM
E rev- Go with a 7xl / MM and 4s Lipo, use a ubec or a rx pack....you would be good to go.
E-Revolution
01.29.2007, 02:23 PM
Thanks, neweuser ! But im suprised, anyone guys in here Finland dont use more celss than 12 NiCad/NiMH, or 2-3s LiPos, because they dont know can use more celss... You mean can use more celss than there read: http://www.castlecreations.com/products/mamba_max.html ?
neweuser
neweuser's Avatar
01.29.2007, 02:28 PM
Many here have tested the MM using a ubec on 4-5s with success. As crazy said, he has a 4s 7xl/mm set up in his truck with no probs.
crazyjr
crazyjr's Avatar
01.29.2007, 09:08 PM
actually the current setup is for 5s, but not tested for heat
the 8000 4s packs will be great for you're setup with a 7XL. I'd go woth 4s over 3s as the power will be better. all you need to run this pack is a UBEC, because the internal BEC can't handle the extra voltage of the 4s pack
