Procharged5.0
Procharged5.0's Avatar
02.01.2007, 02:50 PM
Sorry BP. I've spent some time in/on 1:1 dyno's. They do not give a 100% replication of the real world. But they absolutely and unequivocally give you a bench mark on performance and help you to compare performance changes. IE: Dyno the motor. Change the headers. Dyno the motor. review the gains/losses/power curve, etc. The same holds true with electric motors. I know that it won't tell you the whole story but it WILL tell you something about the motor's power generating characteristics, efficiency, etc. It WILL generate valuable info to be used IN CONJUNCTION with field testing.
