jhautz
jhautz's Avatar
02.09.2007, 07:52 PM
I run the proline shocks with the 3.3 stuff dont have an issue. Are you using the RPM arms or the stock. Im using RMP. It is a fairly tight squeeze with the proline shocks. What shock towers are you using, and which holes in the arms? I had to get the little pegs on the shock towers just the right length to get it all to fit together just right.
Just for reference. This thread has a photo of my maxx with the 3.3 stuff all set up before the I went to the proline shocks. http://www.rc-monster.com/forum/showthread.php?t=3588 WhenI shitched to the fatter proline shocks I had to get the spacing right on the upper shock mounts.
If your shock cups are rubbing on the slidders maybee a small washer between the shock mount on the arm and the hollow ball at the bottom of the shock to move it out just enough to clear the slidder.
to make it...
or break it...
Silent...But Deadly
02.09.2007, 08:06 PM
I was going to suggest the same thing- but maybe used a small shim or two at the top & bottom of the shock to space it off the mounts- should clear the inside of the arm and slider shaft then. Give it a try at anyrate.
