02.13.2007, 12:45 PM
GA- great assembly = http://greatassemblyrc.com/ They sell 6061 & 7075 alloy bulks which are very strong, but a little pricey.
The grey bulks are the newer improved version on the t-maxx3.3, but they should work on an emaxx fine- slightly stronger, and the grey skids too.
The flm combo bulks come in two flavours:
FLM17500
FLM18500
$120.00/set = these take standard maxx diffs (minus the casing).
FLM17700
FLM18700
$140.00/set = these take 1/8 buggy diffs which mike sells, but they will require more work to set them up (shimming and gear alignment etc)
If you are on a budget like me, I'd go for the FLM alloy bulks:-
FLM18001 $37.50
FLM17001 $37.50
They looks lush and are still a great improvement over the stock plastic version. As for checking your diffs, you may have to dismantle them if you cant feel/ hear anything obviously wrong with them
Procharged5.0
Procharged5.0's Avatar
02.13.2007, 01:01 PM
I'd go for the Great Assembly bulk kit. (See Pic) They are $95 vs $75 for the Fastlane machine versions but come with great bulkhead braces, are drilled for easy access to the shock tower bolts, and the machine work is better than FLM's.
I have a set of GA's in the 7075 aluminum and they are excellent! Nothing tougher! I also have their 7075 diff cases and 3mm Ti Skids. (See Pic)
If you can afford the FLM combo bulks they are very nice and provide a diff case upgrade as well.
That being said the FLM combo bulks are the best overall value with the GA's right
behind.
Name:	GA Bulks Web.JPG
ID:	2415   Click image for larger version
Name:	GA Bulks.JPG
Sylvester
Sylvester's Avatar
02.14.2007, 09:52 AM
behind.
NICE polishing Pro! I am forever jealous.. :005: :mad:1
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
turbo4
turbo4's Avatar
03.13.2007, 10:34 PM
Been away for a while but back with a vengence( kinda) I get torn between to many hobbies. Been working on some airplanes for spring and doing some flying indoors:003:
Sporting a new look for the Emaxx. I wimped out on the hybrid bulks and went cheap and picked up the 3.3 grey ones. I got the revo cups for the shocks to set on which gives me the clearance I need over the sliders/3.3 upper arms(thanks Serum). I did spring for the FL shock towers and that really helped running the powerstroke shocks. The stock towers compressed the shocks to much and would'nt allow the truck to bottom, only the shocks would bottom out, leaving the skids 1/2" off the ground. Finally got some real tires, proline mashers on hpi wheels and the Excursion body from hotbodies. I was dissapointed with the this body as the holes were drilled a little off and the antenna hole is on the wrong side. I also picked up some new slipper pegs and the MGT spring like Procharged suggested. Finally got it together tonight and went to the park. After 10 minutes I snapped a center shaft(2nd time) so I guess its time for some real center shafts. Any word on procharge's slipper and the Mamba monster max?
On another note I'm looking for the "stiff" spring set for the powerstrokes, looks like its discontinued from most sources, any Ideas? What weight oil should I run to accomodate 3-5' jumps? I think I got 30w in them now which don't seem to do much.
See ya, J.
J.
Name:	truck stuff 001.jpg
ID:	2553   Click image for larger version
Name:	truck stuff 002.jpg
ID:	2554   Click image for larger version
Name:	truck stuff 004.jpg
