glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.14.2007, 12:22 AM
Yep... depending on gearing and traction, you can pull over 100amp spikes. My truggy with the 1515 hit over 120.
I think the highest I saw with the 1512/buggy was just under 120. But I don't use the eagle tree all the time.
But I have had runs in the street and lower traction tracks that showed peaks around 70-90amps.
At full speed the amps drop to around 30ish but every time you yank throttle and accelrate it will hit at least 50-60amps until the load drops (stops acclerating).
And average for the whole run is like @15amps.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
