Serum
Serum's Avatar
02.16.2007, 02:14 PM
Well, the higher the mAh rating of a cell is, at the same given discharge C, the higher the power is the cells can provide.
4S should be enough for 45 mph. use good cells though, if you go maxxamps, go for a 2P setup.
5S will give you a higher voltage (logically) and at a higher voltage, the setup becomes more efficient. you can use 4S of 4000's or 5S of 3200's to get about the same runtime. Hope this makes sense.
riceman
RC-Monster Gold
riceman's Avatar
02.16.2007, 02:29 PM
Originally Posted by Serum
Well, the higher the mAh rating of a cell is, at the same give discharge C, the higher the power is the cells can provide.
Good point. This would be assuming you are running at the same speed (i.e. what you are limited to by the track)?:032:
02.16.2007, 02:32 PM
I did not factor in mAh because it really does not "directly" affect speed (more on this later); it affects runtime more than anything. And an actual runtime calculation is all but impossible because of the multitude of other factors (drive style, ambient temperature, terrain, wind resistance, drive train resistance, etc).
Now, a low mAh battery can affect top speed indirectly. A low Ah cell usually can't provide a given current without dropping more voltage than a higher Ah/C rated battery can. Example: If you have a 3Ah battery, it's voltage will tend to droop more when drawing, say, 100A. A 10Ah battery will usually have an easier time providing 100A with less voltage droop since the C rate won't be as high. This voltage droop can affect top speed since less voltage is available to the motor/ESC.
This is why I have the ability to select different voltages per cell. You can approximate the droop and then calculate the speed based on that value.
Sower
Sower's Avatar
02.16.2007, 02:43 PM
Nice info guys. Thanks.
Well, I think I might be back to the MM/Lehner now, and go with a larger 4 cell pack and just make sure it's a nice cell. Like a Trakpower or something.
