mm is being HORRIBLE -
02.16.2007, 11:50 PM
hey well idk what the hell is wrong but the rusty will cog SO bad it wont move. so i turn the truck off unplug the black wire plug it in and were good to go. but then like 10 seconds later it does the same thing! pretty much when i stop it does it. i was at the track today and couldnt go around one time because of it!!
im not sending it in the cc because last time i did it took over a month to get it back... no thanks...
lmk what i might be able to do to fix it!!
VIDEO!!
http://video.google.com/videouploadf...1e22bab6204d48
TEAM FUSION
02.17.2007, 12:15 AM
Man that's not good... I would check over all the connectors.. maybe resolder anything not factory.
What happens if you reboot without unplugging the black wire? Does it only work again if you unplug/replug this wire?
I wonder if the caps are fried or something is wrong with the motor.
When you plug in the battery, is there a spark? There should be. If there is no spark, the caps are shot.
I don't know man... I have never seen anything like this with the stock setup.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
02.17.2007, 12:18 AM
ill check all that in a sec! on the fone with my g/f... lol
thanks man!
02.17.2007, 12:52 AM
thanks man!
Hold on now! What's more important; your ailing R/C or your G/F? You have your priorities all wrong! :)
That's All Folks!
02.17.2007, 01:54 AM
Try setting the motor timing to "lowest"
02.17.2007, 02:10 AM
lol my g/f always goes number one :005:
its on the lowest right now...
im going to go get some shrink wrap tomorow and make everything tight... i got wires goin everywhere.. hopefully that will help a little!
BMW M Power!
02.17.2007, 02:36 AM
That so NOT racist...(note sarcasm)
That's All Folks!
02.17.2007, 02:59 AM
set it to "normal", run it, then set back to "lowest"
02.17.2007, 03:46 AM
If it was running fine before, messing with the timing isn't going to fix anything. It MIGHT lessen the symptom, but I don't think it will fix the problem. I had a similar problem recently and it turned out that the Deans on my ESC was glazed over. I changed the plug and all was fine again.
02.17.2007, 03:54 AM
well i am changing the deans once i get the shrink wrap tomorow...hopefully that is the problem...
02.17.2007, 03:55 AM
Did you tried another battery pack?
02.17.2007, 03:56 AM
ya they all do it.. the ones with less power (6 cell gp3300s) do it the worst... so idk really what it could be
02.17.2007, 04:03 AM
You have got the LVC disabled? If yes; try enabling it and disabling it again.. Perhaps something is wrong with it...
02.17.2007, 04:05 AM
idk ill check tomorow! bed time for me!!
thanks for all your help guys!
mm is being horrible UPDATE!! vid now! -
02.17.2007, 12:45 PM
hey well i got bored of trying to fix it so i made a vid of what its doing. i think if i got rid of those wire things and either A. just soldered together the wire so it could never malfuntion. or B. i put another plug on there... that better not void cc warranty....
well the video is uploading..... ill edit this post as soon as it gets done!
ok video time!!!
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
