02.19.2007, 05:28 PM
It's not hard to dremel a flat spot on the shaft. Just make sure the bearing and screw holes are covered so metal dust doesn't get in there. I just held my Neu shft with two fingers and used a small sanding drum on the dremel. Took about 1 minute.
IIRC, If you re-wire the LMTs from D to Y, you reduce the kv by a factor of 1.73 (I think). This allows you to run higher voltage in Y, and lower voltage in D and keep the same rpm.
