MetalMan
MetalMan's Avatar
03.08.2007, 09:54 PM
Last weekend at the track my MM's wires got chewed up very badly by the pinion/spur. Fortunately it doesn't appear/smell like the MM shorted out by the wires touching. I've already replaced the wires, but I'm thinking I will do it over again with some proper 12ga. wire (not sure what the wire is that I put on). I used copper braid to suck up the solder that was in/around the holes to get the new wire in, and then I put solder on the wires (when they were in the holes). Hopefully the Deans Wet Noodle (12ga.) will fit.
