Jammin X-1 CRT motor selection
architorture
Jammin X-1 CRT motor selection - 03.09.2007, 01:05 AM
I am in the process of converting a X-1 CRT Pro to brushless. I eventually want this thing to be sick fast and would like to run 6s once the Monster Max comes out. I am planning on getting one of the less expensive motors and running if from my existing Mamba Max on 4s, then upgrading whenever the Monster combo comes out.
What motor is best for me and where can I get one? I have done the motor selection tool and top speed calculator and it looks like the 6XL or 7XL will work the best. Mike recommended a 8XL also. I am stumped on which motor to get that will give me about 50 mph and 20-30 min of runtime. I am looking at getting a set of maxamps 4s 4000 packs and running 2P. Is this a realistic expectation to get these speeds and runtimes?
Anyone have any suggestions on which (or another) would work best? I will not be racing, but just going fast and taking on big hills and jumps.
Serum
Serum's Avatar
03.09.2007, 02:22 AM
for 50mph i would go up in the number of cells.
50mph on 4S is pushing it currentwise.
Here, please read this;
http://www.rc-monster.com/forum/showthread.php?t=5115
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.09.2007, 10:43 AM
You do NOT want the hot motors like 6xl or 7xl... especially on 6s lipo!!
I think a 9XL is the motor you should run. 50mph would be easy on 6s which is your target. 50mph on 4s would need a very tall gear but could do it if you really want to... 16/46 gearing would be around 45mph or so.
For 6s I would actually go lower... 10-11XL
here's the rpms at 21v for reference:
8XL 41400
9XL 36800
10XL 33100
11XL 30100
30K is plenty.... my truck/buggy run under 24/27k and they do 40+ easy
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
architorture
03.09.2007, 01:30 PM
I wanted to do 6s once the monster max comes out (if it supports it). The motor that I'm looking for now will just run 4s and hold me over until the MMM comes out, that is why I want an inexpensive one instead of a lehner or neu. So how about the 7XL on 4s?
cembom
03.09.2007, 02:17 PM
I am not sure if it will have enough grunt to push your truck realy well but try an xl5 if you wanna run 4s. I would probably go 5s with the 7xl I think. I am a noob and am having my little theories tested by the other members as well but that may help.
Serum
Serum's Avatar
03.09.2007, 03:14 PM
Cembom;
Please be easy with your advices. The 7XL on 5S in a short ratio truggy?
did you read the sticky in the brushless section?
The 7XL can do on 4S, though on 5 or 6S it will get burning hot in the short ratio vehicle.
It's kind of hard to get a motor that suits 4 and 6S. (that's in increase of 50 percent, so it's kind of hard to anticipate on that with gearing and the choice of the motor)
The 7XL on 5S in a truggy is asking for trouble.
architorture
03.09.2007, 03:43 PM
Yes, I read the sticky. I am familiar with lipos, KV, stuff like that from elecric planes and helis. I am not looking for a motor to run 4s AND 6s, I was just saying in the future, I'd like to do 6s ON THE MONSTER MAX ESC AND MOTOR.
I just want an inexpensive motor that will give me close to the speed and runtimes I want on 4s with the Mamba max controller. Is it the 6XL, 7XL or 8XL?
Serum
Serum's Avatar
03.09.2007, 03:51 PM
appearantly I didn't read the 'combo' word in your opening post. No need to shout..
the runtimes would depent, and like i said; 50 mph on 4S is pushing it. (without the capslock) the controller, the motor and the batteries. the runtime you have in mind on 4S combined with that speed is rather hard. (8000mAh isn't enough)
architorture
03.09.2007, 04:40 PM
Sorry, I wasn't yelling, just wanted to make my intentions clear. So will the 7XL be a good choice? (on 4s) I dont have to hit 50, just want a truck that is pretty fast. I have a stampede with a mamba max 5700 on 3s now and I love the power and speed it has. I'm assuming the truggy will not come close to that kind of power/ weight ratio though. If the 7XL will keep cool, give decent runtimes and speed it will be enough to hold me until I get the monster max.
Serum
Serum's Avatar
03.09.2007, 04:50 PM
I would go for the 8 or 9XL, since you are using a rather short ratio.
Sower
Sower's Avatar
03.09.2007, 04:53 PM
So, are you running the less expensive motor now because of the limited ESC's available, or for dollars? If it's dollars, then I have no options for you. If it's due to ESC, why not build with a great motor that you can deal with now and later? I'm going to run a Lehner 1940/10 hi-amp with the MM and a 4s in my X1 CRT and eventually go to a 6s. Just a thought.
And just a word to the newer guys (I guess this would include me) . . . this forum is not like the typical forums out there. There's no flaming, a lot of help, and a ton of knowledge. IMO - best forum on the web. So please just wait a minute before you respond in a way that might seem abrassive. The guys here are truely trying to help.
Good luck whichever way you go, the CRT is sick.
architorture
03.09.2007, 05:31 PM
I could get a more expensive motor now, I just do not want to regret it when the monster max comes out. I am limited to 4s with my current esc, and I do not want to buy a new esc until the MMM comes out.
I was under the impression that the motors are closely linked with the input voltage, therefore the motor I'm running now may not be the best option when I switch to 6s, that is why I wanted to go cheap now and go all out when I can move up to 6s.
I do appreciate everyone's help and this seems to be a great forum. I did not mean to come off as abrasive if that comment was directed towards me.
Sower
Sower's Avatar
03.09.2007, 05:34 PM
Right on. I'm totally with you, and I'm building based on the same assumptions. I will go to the MMM and a 6s when they come out, but don't want to have a temporary motor. That's why I got the 1940/10 hi amp. It's a lower KV (1500) and will deal very well with the higher voltage later. You might try BrianG's motor calculator too. Very helpful. Here's a link for it:
http://www.scriptasylum.com/rc_speed/index.html
Welcome to the forum!
glassdoctor
TEAM FUSION
03.09.2007, 11:36 PM
You can run a milder motor and gear up for now.. then swtich to 6s and gear back down. This isn't a perfect solution but it will work
You don't want to take the advice about going to a slower motor, so I would tell you to get the 7XL that you want right now and just plan on picking up another motor when the MMM comes out, or maybe they will have combo that fits what you want... we have no idea right now what the motors will be like. And they will have motors in the package at first, so they say.
Just buy the 7XL...........
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
architorture
03.10.2007, 01:35 AM
I think I will go with the 7XL for now and upgrade later to the Monster Max.
What is an acceptable range of gearing? If I've read correctly, I only have the 46t kyosho in nylon for the spur?
Are the 7XL's hard to find? It looks like Mike is out of stock.
I wish the Monster Max had a date.. I cant hold out anymore with this CRT chassis taunting me! I can't wait to get this thing up and running!
