A little project - micro-t style
riceman
RC-Monster Gold
riceman's Avatar
Talking A little project - micro-t style - 03.12.2007, 02:38 AM
Well I got my hands on a used micro-t and, of course, felt the need for a little brushless modding. :027:
Got it for a decent price. Came with a bearing kit and a busted rear a-arm mount. No worries on that since it was going to be replaced with aluminum anyway.
ESC of choice was a Mamba 25 pulled out of one of my 18t's. We'll need to do something about the stock plugs and deans ultra in order to get everything as small as possible. Ive seen some folks replace the stock wiring with smaller gauge but I chose not to in case I ever wanted to use the esc in something else in the future.
Now for the battery. Lipo of course. 2S 7.4V to replace the stock NiMH. Lets compare:
Length and width pretty darn close:
And the thickness works too!
We won't be using the stock ESC for the brushless duties so let's get rid of this:
I think we can make this work:
10 image limit on my posts so on to the reply..
continued...
riceman
RC-Monster Gold
riceman's Avatar
continued... - 03.12.2007, 02:39 AM
Well now that the stock controller is leaving we wont be able to use the stock 4 wire steering servo. Luckily I had a spare Hitec HS-55 laying around.
We'll have to do something about that spline though. The micro-t servo saver fits on a hex spline.
No problem - just swap the top two gears from the stock into the Hitec
Wala! new hex splined Hitec
A blurry picture of the servo in it's new home. A little bit of Dremmel work was required here. The tabs on the servo was removed and the case was shaved just a bit. The walls of the chassis were also worked on to accommodate the extra 1mm length of the Hitec servo
Now for some solder work. Motor plugs and micro deans all topped off with a little shrink wrap
one more until I get a body for it
riceman
RC-Monster Gold
riceman's Avatar
one more until I get a body for it - 03.12.2007, 02:39 AM
The heart and soul of the little beast is the 12x22mm 5250kv Feigao
A little more Dremmel work on the motor plate to accommodate the screw pattern of the new motor. The stock motor has a splined shaft so a little CA was needed to keep the pinion in place (a little too small to tap a set screw:crazy:)
Now to beef up the little guy a bit:
And for the e-clip impaired such as myself some nice aftermarket threaded axles
And finally a Spektrum micro Rx servo taped to a smoothed out top plate.
I don't expect to see this guy on Top Gear anytime soon but it is definitely fast enough for indoor mayhem. I would have had some video posted but I immediately busted a front hub (I thought it was the tie rod that was supposed to go?) while doing speed passes up and down the hallway. Aluminum ones are on the way and hopefully I can get some vids posted soon
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
03.12.2007, 05:14 AM
Very nice project there riceman. Definately get some video of the high speed passes.
I just put a 2s in mine yesterday along with the wheel bearing upgrade and a bigger pinion as well. Averaged 19.5mph on the radar. Can't wait to go brushless!
Serum
Serum's Avatar
03.12.2007, 07:58 AM
Excellent Write Up!!
thanks for sharing!
Mr.lst
03.12.2007, 08:56 AM
hmmm it looks like fun I might have to do the same thing.
Sylvester
Sylvester's Avatar
03.12.2007, 09:24 AM
VERY nice riceman! Makes me wanna get one!:)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
jnev
jnev's Avatar
03.12.2007, 06:19 PM
Very cool micro-t. It seems like a lot more of them are popping up as brushless.
Have fun with it!!
squeeforever
squeeforever's Avatar
03.12.2007, 07:42 PM
Mine is sitting right infront of me begging to be BL. :p Soon enough. Just gotta get the Evo V3.3 finished first.
Soya
03.12.2007, 10:52 PM
I like the $100 receiver in the $80 car :dft012:
cool stuff.
03.12.2007, 11:06 PM
Nice conversion! I'm surprised everything fit. Makes me want to pick one of those up. :)
squeeforever
03.13.2007, 12:03 AM
Brian, I would recommend it....The only thing I don't like is its not 4wd...But other than that, it handles AWESOME. Even for something this small and zippy, its easy to control...
riceman
RC-Monster Gold
riceman's Avatar
03.13.2007, 12:57 AM
...unless you do something silly like putting a larger pinion and drop a BL/lipo combo in it:005:
I went shopping for bodies today and am going to try out a couple 1/32 slot car bodies. Everything doesn't quite fit under the stocker anymore.
squeeforever
03.13.2007, 01:06 AM
Yea, I ran into that problem by simply adding Deans Micro connectors...:032:
cembom
03.13.2007, 01:34 AM
Man -O- man. If u are the same guy u kinda helped inspire me to to another project. I cant believe that the micro t can even be driven now. Doesnt it just do backflips when u blow on the throttle? now I gotta get one.
