jnev
jnev's Avatar
03.18.2007, 11:15 PM
Unfortunately, you will not be able to run the 5700 motor with the e-maxx. It is just too small and weak of a motor for such a heavy truck. What you could do though, is sell the 5700 motor and keep the Mamba Max ESC, and run an XL motor from the rc-monster store. This will give you decent speeds and the temperatures shoudl stay down as well, depending on the gearing. With this set up, if you are on a tight bugdet, you can run dual 7 cell packs on each side of the chassis.
